Hunter 31_83-87 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Installing Kiwi Feather Prop
posted 10-07-2008 by Patrick Lombard
Removed the old 2 blade fix prop.
Old 2 Blade Fix Prop
Coated the Kiwi Prop with of antifouling paint.
Kiwi Feather Prop
Removed old 2 blade prop.
Removed Old Prop
Placed new kiwi Feather Prop on shaft.
Placed New Prop
The I/2 nut is tighten to ten foot pounds of torque, I used a pipe wrench to hold the shaft from turning.
Tightening Nut
Loctite was applied to the two locking set screws.
Set Screws
The two locking set screws where installed hand tight.
Installing Set Screws
It took 30 minutes to complete the whole job. The Kiwi Feather Prop cost me $1,250.00.
I ordered it from:
Kiwi Prop North America
E-Mail: westernsales@kiwiprops.com
John Marchant
Cell: (250)715-6450
John was very helpful in getting the right prop for my H 31. I just cant wait till I get the boat in the water to try it out. Will update on performance. This was the easiest upgrade I have done to my boat so far.
Finished
Click image for largest view
