Hunter 31_83-87 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
h34 / h31 Rudders (u gotta see this junk!)
posted 10-07-2008 by Barry Olsen
See Note the Broken Weld
This is where the post failed. There was no sign of rust or corrosion
See Rudder Post Assembly with no Fiberglass or Foam
This is a photo of the original rudder post used on my 1983 h34 hull #56. Very little metal inside it. Appears the Hunter craftsmen crushed a piece of stainless tubing and welded it to the post along with a light frame. Think a rudder like this one would GO THE DISTANCE?
See Close up of Failed Weld
Although this could have been repaired Foss determined I needed a complete new rudder
See A View from the bottom
If I was to have a new rudder ever made again I would pay extra and have this assembly beefed up before the foam and glass were applied. How far off shore would you go knowing this is how your rudder was made?
Click image for largest view
