Hunter 31_83-87 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Emergency Tiller for Wheel Steering
posted 10-07-2008 by Steve Dion
This is an emergency tiller for a 1985 Hunter 31
First View
This is the stalk that fits down inside the rudder post.
Close up view
Here is the tiller attached to the rudder post. I must tell you that I would not want to steer the boat in very heavy seas with this arrangement. It may be fine if you were in calm waters but you would also probably want to have a towel or something to wrap around the end of the tiller.
Attached.
Click image for largest view
