Hunter 31_83-87 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Stainless Steel Hand Rail Replacments
posted 10-07-2008 by Steve Dion
The boat is the Heather Marie a 1985 Hunter 31. This is a view of the finished product. These rails were made by one of the shops in the S.F. bay area. The centers were made to fit exactly where the original hole from the teak rail came off. The rail are made of 1 stainless steel tube with bolts welded to the bases.
All of the holes were drilled oversize and filled with epoxy. Then they were redrilled to the proper size. The holes go through the headliner. The holes were caulked and fitted with large washers on the inside and fitted with acorn nuts.
Maintenance is now to a minimum. Only the eyebrow over the windows and a few pieces of teak in the cockpit are all that remain to keep up.
Replacement Hand Rails
View looking aft
Here is a close-up view of the end
Another view
Another exterior view
This is the inside view with the nuts and washers in place.
Inside view.
Here is another inside view of the finshed product
Click image for largest view
