Hunter 45CC Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Passage 45 upgrades 4
posted 10-19-2012 by Stephen Ribakoff
Forward head access panel
I cut the panel that concels the water lines and head fresh water solenoid. By doing this I can now store light weight items like paper towels and toilet paper.
Cockpit table extension
I fabricated an extension to the cockpit table using Starboard of the same thickness that slides under the existing table using strips of starboard sliding into 3/4 inch PVC pipe clamps. This makes a easily removeable extension that can be stored under the desk in the aft cabin using the same technique to support the table extension.
Sheet holders
Using mesh material that is attached to the arch allows me to hang the sheets off the deck with good drainage and drying
Rain catcher
We use our boat for live aboard and try to catch rain water when possible. This catcher can be put up in less the 2 minutes and drains directly into the forward water tank. The two aft lines attach to the jib sheets. The remainder of the supports for the catcher use quick connect snap shackles to the life lines. A line under the thru hull fitting attaches to the forward cleats to hold the center down for good drainage.
Deck Box
I mounted a deck box to the back of the cockpit which hold our dive gear and realed beach toys. On the front is a cushion for the helmsman and on the sides are drink holder and pockets for the winch handles. On the back (not shown) are 2 more mesh bags for small wet items.
Click image for largest view
