Click for larger view
12 volt wash down pump. powered by unused fwd entertainment circuit (hunter 45cc) or can run off any convenient 12 line. No need to use thru hull fitting. Simply hang intake hose over the side of boat, Not shown is SPST water proof on/off switch.
