Hunter 28.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Iron keel Maintenance
posted 09-12-2008 by Warren Milberg
Once you have the iron keel nice and clean, my suggestion would be to use the POR-15 system: Metal Clean, Metal Ready, and then POR-15 paint.
I did this with my H28.5 keel about 5 yrs ago and it has worked well. Only a pinpoint of rust bleed through here and there since and annual keel maintenance takes less than a half hour each spring.
