Hunter 28.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Inexpensive Air Conditioning
posted 09-12-2008 by Karl Bradley
How to install a 5100btu Sears window a/c in a hunter 28.5.
Move top step up abput 2.
Have drain tube drain into shower drain.
Add gasketed access door in cockpit companion way.
Build cover and internal ducting to guide airflow. This works so well that I have to turn the unit down two times in the middle of the night in Florida.
