Hunter 28.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
B Yanmar Engine Panel
posted 09-12-2008 by Warren Milberg
Questions: Hunter 28.5 Engine panel part number
I pulled the engine panel from my Hunter 28.5 because it was cracked around the engine stop. The engine stop cable was also broken probably from being kicked. Anyway, I am making a plexiglass cover to protect everything but I need a new panel and stop cable.
Does anyone have a Yanmar part number for the panel and the stop cable? Ive looked around and although I found a diagram of the panel I need I cant find a part number. The engine on board is a Yanmar 20GM20F. Thanks!
Answers:
That is called a B panel. The bezel is available for around $25.00 at most dealers. I dont have the part # handy.
I found this B panel part # on the marinedieseldirect.com web site. 129271-911119. It had a price of $747.75 I would talk to them before ordering to make sure this is the one you need. There are many diferent panels.
For a Yanmar B type panel its 128170-91010. I think Im going to try and reenforce the area around the stop cable pull so there be less of a chance of cracking the panel again.
Fred, Try Gallery Marine in the U District on the waterway... I replaced the B panel bezel on my 1980 30 (2GM20F) for the same reason last summer. The cable is pricey ($100) but the panel was about $25. They are are a Yanmar parts dealer and were very helpful in getting the parts etc.
