Click for larger view
Once hardened the base is removed. The pad is sanded smooth and corners rounded before applying gelcoat.
Then pad is read to drill and countersink for thru hull fasteners with backing washers.
One hole will most likely hit the existing aluminum deck plate, but just drill through it.
Angle slightly to allow room below for socket against the hull.
The liner was cut away in these areas for access. To be trimmed out later to make presentable.
