Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Baums Rush 3 improvements
posted 10-07-2008 by John Baumgartner
750 Watts, I figure about 1400 Watts running
Microwave
note: aluminum braces for microwave under cabnet
Refrigurator
remote for inverter ON/OFF, below and to the right one of three AC outlets, 2300 Watt inverter powered by three type 27 gels 410 AMPHours, AC master cutoff switch, and far right AC controller box
starting on left
picture taken while building
AC
in the normal position
27 Gel
AC 115 V convineance outlet, AC control box, ambient air intake for AC, output of AC going forward.... cold and well as heat
left to right
smart charger, 3 stages
40 AMP True Charger
for the auto pilot
flux gate
4 watts and back of VHF Xmitter
Cell phone amp
holder for remote auto pilot,flat screen HD TV, mount for outside TV antenna, fire ext., inside/outside temp. monitor, DVD player, front pannel of 500 Watt inverter. note curtains above and to the right
Top left
Click image for largest view
