Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Baums Rush improvements 2
posted 10-07-2008 by John Baumgartner
fully adjustable for and aft,you can also see the autopilot left top
Captains seat
auto pilot
15 AMP service, under the stbd drink holder
shore power connection
remote mike (VHF), 12 volt socket and a DC 3 way switch
aft starboard
it is Raining, I bought this on this site
rain cover
Volts, Amps, time since last full charge, percent of charge remaining. I carry three type 27 gells
Battery monitor
I made thru alot of trial and error. Makes it soooooo much easer to go below. The doors are removable and just as water tight as the orginal slats
Companionway doors
they fold like an accordenaion (SP)
doors open
and half door closed
Battery monitor
Left orginial DC pannel, center A/C control box fully programmable, right AC pannel with volt meter and reverse connection alarm, this works on shore power or inverter power
Electrical Pannels
Electrical Pannels 2
2 burnner. I like much better (and cheaper) than orginial
alcohol stove
added under the stove
shelves
makes ice (top part)
inside
added under gally sink
shelves 2
in place of the ice chest. Works on 12vDC, 115v 60HZ or 230v 50 HZ..... power seaking. takes 4 amps with a 15% duty cycle at 85 deg
Refrigurator
Click image for largest view
