Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H26/260 Table
posted 10-07-2008 by George Kobernus
See I like to keep it up out of the way most times.
Its amazing how much room there is in the cabin with the table up out of the way. I just use a stick to prop it up. Some people drill a hole in the upper part of the compression post and use the bolt to keep the table up and from swinging back and forth. But I wanted an easier solution.
See H26/260 Table
The H260 table is very flexible
See Sometimes the simplest solutions are the best.
I did not want to do any drilling on the compressions post but I wanted to ensure the table was rock solid when in the up position. After trying several solutions, I found that a strap from Home Depot with hooks on each end worked best. Its rock solid and easy to hook up and take down. No drilling.
Click image for largest view
