Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H26/260 Remote Control
posted 10-07-2008 by George Kobernus
See Placement of remote control
I have a wheel on my H260. Docking under power is much easier with an outboard remote control. I looked at the Edson controls, but that solution requires two levers and you have to reach over/through the wheel. This solution is much cheaper, allows more freedom to move around the cockpit and requires only one lever. The warm up lever (choke) and key are also integrated into this control. Paid about $200 for the control.
See Another shot of the remote control setup.
Im very satisfied with this arrangement.
Click image for largest view
