Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H260 Rudder/Motor Steering Linkage
posted 10-07-2008 by Ross Chamberlain
See Rudder/Motor Steering Link
Looking from port to stbd. A stainless steel tie-rod spans between the rudder post bracket and the outboard. The L bracket above the rudder post bracket allows the tie-rod to connect to the upper pin
Click image for largest view
