Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
My 260 Improvements
posted 10-07-2008 by John Baumgartner
installation was simple and stright forward, while I was at it I did some fancy small line work around the wheel
Installed auto helm
The flus gate position was a problem, didnt know where to put it, the placement of other megnatic articles was important, finial placement was fwd port bulkhead, aft bunk.
flux gate placement
placement was a concern when in operation, this seems like a good place.. out of the way but can be an easy reach from the helm station, waterproofed the attachment place and as an extra precausion calked around the fixture, it has worked great on a 14 day sail and 4 weekend trips
placement of the auto helm instrument
I use this DC ckt breaker for the addition of three DC outlets below decks
added 15 amp. crkt breaker
The placement of my three new goodies, upper left-remote mike VHF, upper right 12v power outlet, lower middle ON-OFF-Both Switch
on-off-both
20AMP true chager is port side aft bunk on other side of wet locker I use an extension cord to go to Honda 1 K gen or shore power when on the hard. Plan on installing AC this winter and running the generator for the AC
True charger
Monitors Voltage, amps used, amp remaining etc, seems like this is a good location, I look at it very time a go below decks
AMP HR meter
This lamp fixture has an adjustable spot and a defuser lights up better than stock
new lamp fixtures
Floresent light right above the table, make it great for table games, cards, etc. less power and lights up the whole cabin, note cheap fan, works ok but draws a lot of power.
floresent light
I had to cut down the mounting shaft to get the height right, it moves foward and aft and rotates, since Im very tall, 5ft 4 it is correct for me, and I can see fwd sitting down, oh ya I had to buy two, used one, so if anybody want the other $100. plus shipping its yours
Captains Seat
used 3/4 marine plywood, will paint it with epoxy
Captains seat beneath
New wife wanted new stove.. a two burner. had to do a little cutting but seems to fit ok, work better that stove it replaced.... oh yah, if anybody wants the orginial one burner stove e-mail me LKYusnret2@aol.com
new stove
better stoping power, no adjustement required, self cleaning SS I had no problems so far driven about 3,000 miles, plan on putting the on rear axle this winter
disk brake trailer
add new shelves, under gally sink and under stove, glues braces on bulkhead, screwed thru cabnet walls, big problem was the fit and finish inside the fiberglass walls
shelves
shelves II
fits ok, wanted 2 on board on each side of stove
fire extunishers
in overhead above table, lights up cabin all by itself,
floresent lightting
Click image for largest view
