Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Mermaid M5 AC Unit Installation
posted 10-07-2008 by Clay Thaxton
The Mermaid M5 AC Unit installed in the area under the v-berth space. The opening did not have to be cut. The unit is installed on top of the water tank on a poly board.
Mermaid M5 AC Unit under v-berth.
The unit comes with a 120 volt 20 amp circuit breaker and thermostat with control wiring that connects to the power panel and then to the ac unit. The discharge through the hull was installed 6 above the water line.
Power Panel and Discharge through the hull.
This is one of the three supply air grilles and one of the two return air grilles that were installed. The 4 flex duct used for the supply air was easily installed within the boat.
Supply and Return Air Grilles
The thermostat was installed in the galley area. I think Hunter made a special place for it. It just fit to good in this location!
Digital Thermostat
Click image for largest view
