Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H260/240 motor bracketts
posted 10-07-2008 by Jim Seamans
See View 1
To fix the flexing in the motor mounts of the H260/240, I used the old brackets to obtain the needed bridge. A marine engineer had looked at the old brackets and said this is one quick fix. We just welded a piece across the middle. He told me if this still flexes that we could weld butt joints to both ends of the bracket. Idealy this mount should be rectangle box of around 2-3 square and 4 long. Ive got a friend who builds race cars and has all of the right equipment to do this.
See View 2
Just a different view of the brackets. They need to be cleaned up and will paint them.
Click image for largest view
