Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H260 Motor mounts
posted 10-07-2008 by Jim Seamans
See Port side
From this picture you can see the upper lefthand corner is pulling away from the transom. Starboard appears the same.
See Port side looking down
Looking down on the bracket you can see how it is pulling away and twisting into the center. Both sides show this behavior.
Click image for largest view
