Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Easy Furler Carrier
posted 10-07-2008 by Joe C.
I made this from 4 sewer pipe. I just split it in half and then cut the holes for the back of the mast base to lock in to. It was easy to make, is easy to set-up and gives the furler good support while allowing the forstay to be held straight along the length of the mast. The pipe is 62 long.
Click image for largest view
