Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
PHOTOS Rudder/Motor Connection
posted 10-07-2008 by
See Rudder Post
The rudder post hook up. I used a c-clamp and a threaded bolt. The bolt is a 3/8. This is low tech/low budget but it works. It is firmly clamped to the rudder post but if the motor gets bound up it will release.
See More of the same
More of the Same. The threaded bolt is out of the way of the kick up rudder by being off set slightly.
See Port of Call
Along with the connection you can see my port of call. I sail Lake Wilson.
See Overall Picture
Just a general view of the arrangement. Again low tech.
Click image for largest view
