Hunter 28 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
head tank aluminum tank replacement
posted 06-22-2015 by cdnmurse
As many others before me, my aluminum tank slowly leaked the golden fluids it was meant to hold. Tiny pinholes from years of acid and bile and excrement ate through the tank. This was initially noted by a rank odor coming from the bilge.
The job was big.
A poly tank was purchased from California; still cheaper than purchasing in Ontario even with the exchange rate and shipping (by $100), with a thicker tank to boot.
I had to cut a hole in the bulkhead, which I confirmed was acceptable from the people at Marlow-Hunter.
Big job, glad its over.
Note to others; careful reaching in from the cockpit to do repairs. I almost had to call for help to get out.
Click image for largest view
