Hunter 27_75-84 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H27 Reefing procedure?
posted 10-07-2008 by Bob Early
See 1978 H27 Gooseneck slide
Shows the 18 inch section of the slide used to raise the boom when reefing. Note the absence of a handy billy to bring the boom back down.
See 1978 H27 Gooseneck assembly
This is the sliding gooseneck which also has the spring loaded pin that hits the detent in the black slide.
Click image for largest view
