Click for larger view
The wires coming up and out of the mast were being wrapped with ties externally around the spreader poles and each time the boat came out they must have cut and reconnected the wires, I didnt like that so I drilled a hole in the area where the wire comes out of the light fixture, then ran it inside the spreader pole. I used these waterproof connectors that I can disconnect each time. I ordered them from Delcity.
