Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Tiller holder
posted 07-11-2009 by John Denison
Hold that tiller while trailering and during the night. A piece of PVC tee and a pin to hold it to the cockpit table leg and you are set. I did have to file out the ridge in the center of the tee that is normally used to stop the pvc pieces.
Click image for largest view
