Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Rudder pin for trailering
posted 05-12-2009 by John Denison
I added this stainless steel pin to the rudder as extra insurance while trailering. As you can see, I originally drilled the hole in a different place and had to move to the location as shown. After drilling, I lined the hole in the rudder with epoxy and slipped the pin in with WD-40 on it so it would release.
Click image for largest view
