Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H26 Shift
posted 10-07-2008 by Jeff Morrison
See Another Top View
See View from Port
The red linkage shown here easily slides down by itself when the motor is tilted forward.
See View from behind
The controls are convenient here yet out of the way when not needed.
See Top View
Note the addition of 30 Amp shore power and the external fuel filter/water separator. There is a black rubber boot just above the fuel filter that allows the electric cable to run inside to the batteries. Youll find it easier to access everything inside if you remove the bulkhead in the aft berth. Just a few screws and it pulls out.
Click image for largest view
