Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Hunter 26 with spinnaker
posted 10-07-2008 by Rick Engle
See Soft Prairie Breezes
This spring, we purchased a used asymmetrical spinnaker that is slightly larger than the specs listed in the manual (29 luff). So far, it seems to work best on a broad or beam reach.
See Adjustments in the Settings
Often, it is difficult to get the spinaker and main to work together, especially with a good puff. However, in light wind conditions, the spinnaker makes a significant difference in speed and excitement levels!
See Showing off
Theres nothing like a little colour on the open prairies.
Click image for largest view
