Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Bulkhead Compass
posted 01-20-2017 by Doug J
Click for larger view
Plastimo Contest 101 compass.
The hole was cut according to the template provided, using a hole saw. Nylon spacers were put in between, allowing SS nuts/bolts to be tightened securely. Its important to use SS bolts as they will not interfere magnetically.
The Plastimo Contest 101 compass is view-able from inside the cabin.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
