Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Dual Batteries w/larger Mounting Platform
posted 07-06-2016 by Doug J
Click for larger view
I finally finished installing two new 6 volt golf cart batteries, and cleaned up all the wiring in the aft compartment.
First, I needed to make a new platform to hold the two 63lb batteries. The original platform was not going to cut it, only big enough for one battery.
I made it out of 3/4 Birch plywood and Poplar, cutting and shaping it to fit the contours of the hull, in an effort to maximize surface area. I primed and sealed it real good with three coats of Rust-Oleum Topside paint. I used Oyster White, which is a real close match to the color of the inside of the boat. The new platform is fastened to the old one with six #12 SS screws. A 3/4 piece of Poplar provides the starboard side with vertical support. The new platform is very strong, Im sure it will hold the 126lbs. nicely.
I plan to add a Flow-Rite battery watering system to make it easy to top off the batteries, as they are not easy to access.
I ended up moving the 1800 watt Inverter to the starboard side away from the batteries, along with the battery charger and shore power GFCI outlet.
Im happy with the way it all turned out. Next I am working on a replacement bulkhead panel to replace the one the PO hacked up. Then I plan to install a Solar system.
(It has been suggested to install a 1 inch high frame around the battery boxes to make sure they cant move around and pull free of the straps. So, I will heed the warning and will be adding that for safety.)
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
