Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Table mods
posted 01-16-2016 by dewhunter
Click for larger view
Another option for the triangle shaped table. I took a36x60 table top and drilled a 21/8 hole in it and mounted it in the same location as the original table. Works the same as original but I gained eating comfort from reduced side angle when seated.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
