Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Propane tank
posted 01-16-2016 by dewhunter
Click for larger view
20 lb propane tank on aluminum bracket. Proper APROVED GAS BULKHEAD CONNETOR AND HOSES ARE REQUIRED. You cant cheep out here. Hydraulic fittings have a different flare angle than gas fittings and hoses will not seal in gas. They are made for fluids. Propane is safe as long as you play by the rules. Note: squared off rudder with slight bulbus end. This mod took the slight chatter out of the tiller at higher speeds.
On the dock with bbq mounted
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
