Hunter 26 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
anchor roller
posted 01-16-2016 by dewhunter
Click for larger view
The lower mount is under the furler mount and secured to the hull/deck joint by the 3/8 ubolt.
The anchor and track is below the furler on the starboard side. The front of the anchor is centered with the bow and the slight offset clears the furler with the chain lining up with the hole in the anchor locker cover.
Another view of the offset. Also filling the water tanks.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
