Hunter 25.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Fish Easy 2 and Power Panel Install on 25.5
posted 10-07-2008 by Dave Busby
I used auto gasket blue RTV to fix x-ducer just forward of the keel.
Fish Easy 2 Skimmer Transducer
I used a cabinet self-closing hinge to mount the swing-arm that I made myself.
Fish Easy 2 on Swing-arm
Fish Easy 2 swung-out
You can see that the depth numbers are easy to read even in bright sunlight.
Fish Easy 2 from cockpit.
I installed a high quality AC panel, battery swith, and DC panel, and AC outlet just below the companion way. I installed 30 amp AC service, with proper 10 AWG wiring, and improver the DC wiring also.
Power distribution panel
I mounted the charger just below the companion way, just under my microwave. It works great and fairly easy to get to.
True Charge 10 AMP charger
Click image for largest view
