Click for larger view
100Watt solar panel mounted to Bimini !!
GeminiMarineProducts.net has these really cool contoured stand-off brackets that mount to the rail of the bimini.
Mark the holes, center punch it really good, drill, tap, I mounted with a leather pad
under to cushion against the bimini fabric.
Never will worry about dead battery in Miami anymore....
(This is an upgrade from the 15W system I had, upgraded when I put the Washdown pump in)
