Click for larger view
Answering perhaps the most crucial need on a sailboat, a place to stash your beverage when you need to come about, I came up with a solution that I challenge anyone to beat in terms of inexpensiveness and flexibility. I used the thin-walled pipe (white outside, black inside) typically used for low-pressure applications like underground drainage. Much lighter and easier to work with than Schedule 40. $10 for a 10-foot piece. I cut it into several 5-1/2-inch pieces to start with.
Photo shows final product mounted in aft cockpit corner of a Hunter 170.
