Click for larger view
Wanting a place to stow an anchor, ropes, small ice chest, etc. I built this stowage locker using materials purchase from Boat Outfitters. Two pieces of 27x24 Arctic White King Starboard Plastic Sheets, two Stainless Steel Take-A-Part Hinges 1.5 x 1.5, and one Seafoam Flush Boat Latch. I started by making a cardboard template for the lid, then cut and mounted the plastic sheet. This made it easier to create the template for the front. I cut several strips 3/4 wide to use as mounting cleats and used stainless steel screws, countersunk, to attach everything. I plan to round the sharp corners and add some non-slip material to the top of the lid. Contemplating putting a net pocket on the underside of the lid for stowing things like gloves, flashlight, hats, etc.
In addition to providing stowage space (not meant to be watertight, by the way), it provides a nice place to sit if you are not running a jib.
Total cost - $164.91 not including screws.
