Click for larger view
Overall, it came out looking OK and the repaired area was strong. During the repair, I spilled 1 drop of epoxy on the hull. I still cant get that drop off the hull, so I think that the type of epoxy I used will probably be strong enough.
Unfortunately, the motor mount itself was now the weak point. Since it appears that the metal in the mount has been rewelded already, I figured that some reinforcement was warranted in this area. I decided to make an arm bracket that was similar to the one that Hunter used on the 170s larger cousin, the 212.
