Hunter 19_81-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
1981-83 H19, an Overview
posted 10-07-2008 by Nicholas Nick
Boat on trailer
boat on trailer, intro shot
Floor board are home made from Cedar. Note plastic coated wire with hook hanging over the stern to the right. That keeps the motor with the boat, should it ever try and jump ship.
Cockpit floor boards, outboard teather
Mast base
The mast is attached useing two pins. I can walk the mast up into position with out too mush trouble. Im sure as I age this will change.
mast base tilt
Split back stay
The steel cable back stay comes down from the mast and ends in a pulley. Through the polley runs some high quality/strength rope that is tied off on deck anchors on each corner of the stern. By adjusting the line/rope through the pully one can adjust the back stay tension.
Back stay closer look
Close- up of rope/pulley in back stay
Pulley to raise and lower swing keel
I added hooks and straps to hold floor boards and cushions in place while trailering.
Cabin and swing keel trunk
A piece of wood bolted to the trailer supports the wieght of the keel when on the trailer. I need to put some foam or carpet on it to protect the keel.
Trailer Keel support
Click image for largest view
