Hunter 23.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Batteries Moved to Forward Compartment
posted 10-07-2008 by Rick Webb
This is looking forward into the locker under the v berth
Switch and Charger
With the charger I have now they are not necessary. But the idea was to be able to hook up the charger without removing the battery. The positive post required a cover so I just bought a post with a cover. The nepgative post is just a peice of plywood that I put a brass screw through and varnished.
Positive and Negative Posts
The batteries are in the aft portion of the locker. The starboard was simply laid on top of the ballast tank and held in place with some 5200. I think the starboard was purchased as a 24 X 27 1/2 sheet and just fit through the opening. Mark the position of the battery boxes before you glue it down and attach the hold down straps while it is out of the locker. I had to do mine left handed while upside down, would have been much easier if I had done it before gluing the board down.
Looking Straight Down and Aft
Inside Looking to Port
Click image for largest view
