Click for larger view
Not much room on he 27-3 to store stuff. This is a cubbyhole keeper that adds some space for pencils, pens, cellphones, and other stuff. Its made from a bit of teak pinrail. Measure front and side and cut 1/4 in to 1/2 in over to allow for fitting. Cut at 45deg angle and use epoxy to glue; hold with a picture rig or other fixture while the glue cures. Then carefully trim the front and the side. Note that the bulkhead and hullside may not be square to the top. Use 3M double sided sticky tape to hold in place (make sure to wipe teak with acetone first).
