Hunter 33 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Adding a drop in freezer
posted 09-01-2014 by Tom
This past weekend installed a Engle MB40 drop in freezer. First i removed the ice box and rim that holds iti in place. Second I made a bracket out of plywood and mounted it under the corian counter. Next I ran the wiring to the DC panel and placed a 10 amp thermal circui breaker in spare opening. Now iconnected wire to freezer and dropped in. After 3 trys on getting the compressor in the right position on the freezer it fit great. Now all i had to do is mount the lid to the Corian lid with silicon and added 2 hinges to complete install.
Click image for largest view
