Hunter 23 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
SINGLE HANDED MAST STEP
posted 10-07-2008 by John Sylvester
One end attached to jib halyard. Boom vang attaches to connection for jib foot
Attachment to bow
This supports the mast while raising/lowering. Each side consists of 2 legs of beided cable each 21 inches long swedge to an O ring on one end and quick release at other. Legs and O ring is connected to mast 6 ft braided cable. One leg is attached to shroud attachment and other leg is attached to base of rail fwd. SUPPORTS WILL BE SLIGHTLY LOOSE WHEN MAST IS RAISED - YOU DONT WANT IT TIGHT.
Mast support
Mast support connected to mast with a quick release. Other end is swedge to O ring - THERE IS ONE PER SIDE
Mast support
Fulcrum is attached to mast using two 3 inch U bolds. Talked to Hunter and did not recommend direct mounting to mast like later models without serious reinforcement of mast. This was the best compromise.
Fulcrum
One hand controls the 9 foot pole and other hand release the line on the boom vang. The vang stop is at the top (pole end). This allows me to have full control while standing to control descent of mast.
Lowering the Mast
Mast resting down. This system is safe and simple. Idea came, with a few modifications, from catalina27.org.
Mast down
Click image for largest view
