Hunter 216 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Various H216 improvements
posted 10-07-2008 by Jeff Prideaux
A swim ladder is important to be able to get back in the boat. It comes in handy both on the hard and in the water.
swim ladder
trailer guides help line up the keel for retrieving the boat on the trailer. They are well worth the money. I also keep my boat fully covered with tarps to keep the sun and leaves off it. I use a silver tarp to reflect the sun.
trailer guides and tarp.
A spare tire will be much appreciated if you have a flat on the road. I placed it near the bow by the trailer mast support.
spare tire
Stick on hooks will help keep your gear off the floor. These can also be removed if you later change your mind or want to re-position them. No holes needed.
hooks
While wintering, I like to use an extra mast support to help keep the mast from bending due to water or snow building up on the tarp. Although, since I keep my boat in my driveway, I can check on it after each rain or snow storm.
extra mast support
Although too small for adults, the area under the tarp (over the boom) is a nice place for kids to play.
boom tent
Click image for largest view
