Hunter 216 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Reefing a H216
posted 10-07-2008 by Jeff Prideaux
My Hunter manual doesnt say how to reef the mainsail. The following pictures show how to do it.
This shows that the reefed sail doesnt go all the way to the top of the mast.
shortened sail
This shows how to reef at the mast. The main halyard was loosened to let down the sail a bit and then tied back off. The yellow line is the reef line.
lines at the mast
The blue line is the reef line. It is tied off on the mast, goes through the eye-hole on the sail and back down to the block on the other side of the mast.
bitter end of the boom
This shows the blue reef line going through the block and continuing on down the boom back towards the mast.
Other side of bitter end of boom
This shows where you tie off the blue reef line.
I leave the yelloe and blue reef lines attached all the time so it is easy to reef and shake the reef out.
tying off blue reef line
Click image for largest view
