Hunter 356 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Splash guard for 356
posted 10-07-2008 by mark personne
6 mm security glass custom made 75 USD, brackets intended for a bathroom shelf 50 USD. Didnt want to drill holes in the Corian so I used epoxy glue, seems to stuck OK.
splash guard mounted
Added a sea-water tap for washing and washing up. Salinity in the Baltic sea is less than 1%. The blue bucket on the table is a dryball with crystals in, used to absorb moisture during winter-time.
Sea-water tap
Click image for largest view
