Hunter 290 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
290 Enclosure and Radar Mast
posted 10-07-2008 by Eric Drayman
See Enclosure with Dodger
We had a local canvis shop create a dodger and enclosure using the stock bimini that Hunter provides. There are a total of 9 panels and the dodger. The dodger has a fly to the bimini that finishes off the enclosure. The back has screens and the fly can be replaced with a screen. There are two additional vents in the arch.
See Close up with Radar Mast
We opted to install the radar on its own mast. The mast has a manuel leveling device. It only took us about 12 hrs to install the Radar.
See Another angle
You can also see that we decided on JRC. Found a 1500 on ebay for a great price.
See Roll up
The center panel is rolled up. All the panels can roll up and thus the enclosure can be put away in less than 10 minutes. We can also sail with the enclosure as you see in the picture but have not as of yet.
See Just another angle
Another angle
See Flag
Flag
See Dodger
The center panel of the dodger rolls up. Side panels also remove from the dodger. You can also see the Fly.
See Side shot up close
You can see what a great job the canvis shop did.
Click image for largest view
