Hunter 42 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Cutter rig
posted 09-12-2008 by Terry Cox
Hunter offers a P42 cutter add on option. The mast is already set up with the sheave, but a chain plate bracket needs to be purchased from Humter Marine that is installed onto the aft anchor locker bulkhead. You also need to purchase all of the other stuff, e.g., winches, sheets, sails, etc., to finish out the conversion.
