Hunter 42 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Alternate Mid-Shift Cleat
posted 04-22-2021 by Puesta del sol
Click for larger view
Installed new cleat. Removed the existing rail entry piece. Cut out aluminum rail. Cut the original piece in half.
The pieces don’t align 100% given the slight curvature difference. Might be able the angle the vertical part of the rail a little better.
Was careful to only cut away enough to install the piece in existing hole
Seems to work well
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
