Hunter 42 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Starboard - Additional berth
posted 02-26-2021 by Puesta del sol
Click for larger view
Wanted to have an extra temporary birth. The boards folds up for easy storage in the V-Berth.
The berth is usable for someone under 6
Support legs are easily installed with bolts and wing nuts. This makes it easy to setup and breakdown when not in use.
We are able to use a camping / sleeping bag air mattress.
The only draw back is the A/C under the bench seat will be a bit loud for light sleepers
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
